1. LezCronut's Avatar
    Security > Screen Lock > None (=no screen lock) is GONE! After I updated to ๐Ÿญ, for a few hours the option for "none" was available, now it is suddenly gone. I love the feature a lot. Please, anyone tell me how to turn it on again! ๐Ÿ˜ญ๐Ÿ˜จ
    11-20-2014 11:09 PM
  2. fuzzylumpkin's Avatar
    Have you encrypted your device or anything?
    Wubba lubba dub dub!
    11-20-2014 11:40 PM
  3. rrballer11's Avatar
    Isn't it swipe?
    11-21-2014 12:28 AM
  4. LezCronut's Avatar
    Some people in the internet have experienced the same thing. And I have solved it. One of you WILL DEFINITELY encounter this, because we lick the same Lollipop.
    Wat up? So if the guest mode is turned on, the main user lock screen cannot be disabled. The minimum security is Swipe. You cannot have no lockscreen at all when there is a guest user activated.
    So you have to go to the guest account, then delete that account from its own setting. And voila.... The NONE Screen Lock is available again for the main host!
    Case closed.
    11-21-2014 12:43 AM
  1. YouTube controls missing from full screen
    By Xandor in forum Samsung Galaxy Tab Pro 10.1
    Last Post: 12-07-2014, 04:18 AM
  2. would a factory reset help battery life
    By currentdroiduser in forum Samsung Galaxy Note 4
    Last Post: 11-21-2014, 03:03 PM
  3. When I download apps, why does LIFE360 open?
    By arkelmerff in forum Android 4.4 KitKat
    Last Post: 11-21-2014, 12:45 AM
  4. screen rotation doesn't work
    By joshua roland1 in forum Samsung Galaxy Note 4
    Last Post: 11-20-2014, 09:44 PM
  5. Hit power button to lock video display?
    By Katrina White1 in forum Samsung Galaxy Note 4
    Last Post: 11-20-2014, 09:28 PM
