1. GlassRat's Avatar
    I'm having a problem with my Nexus 5 back camera: I had the camera set to 16:9 6MP,but when at max zoom the image recorded by the camera is not what was displayed on the screen - it chops the top of the picture off.
    The problem goes away if I select 4:3 8MP mode, but I would prefer to use the 16:9 ratio.
    The phone is running Android L, but I've only had the phone a couple of months and I can't tell if the problem was there before the update (this was the first time I needed to use the zoom).
    Thanks in advance for any suggestions.
    11-21-2014 01:32 AM
  2. Sherwet Rashed's Avatar
    I have the same issue. I'm also running lollipop, but I'm certain the problem wasn't there before. I couldn't find this bug anywhere else online, so I guess it's just you and me for now.
    11-22-2014 01:48 PM
  3. lyallh's Avatar
    I have exactly the same problem on my Nexus 5. The problem was introduced with Lollipop - I use my camera frequently and did not see this before the upgrade. I hope someone at Google will look into this for us.
    11-23-2014 02:25 PM
  4. lyallh's Avatar
    You can vote for this bug on code dot google dot com with issue number 80362.
    11-23-2014 02:30 PM
  5. GlassRat's Avatar
    I struggled to find that issue on the website - in the end I just googled "bug 80362 camera" and found it that way.
    11-28-2014 01:43 AM
  1. Google Play Running in Background Draining Battery
    By Ivan Piacun in forum Samsung Galaxy S3 Mini
    Last Post: 03-11-2015, 04:35 PM
  2. Nexus 7-13 no wireless file sharing in 5.0
    By YaSo in forum Google Nexus 7 Tablet (2013)
    Last Post: 11-26-2014, 07:50 PM
  3. How to turn off notification pop up in Edge screen?
    By boriqua2000 in forum Samsung Galaxy Note Edge
    Last Post: 11-21-2014, 12:19 PM
  4. How to play DVD in PC Optical drive over LAN on N7 13?
    By Machinist60 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-20-2014, 11:33 PM
  5. New Motorola camera update just arrived
    By Cajun_Mike in forum Motorola Droid Turbo
    Last Post: 11-20-2014, 09:58 PM
