Galaxy Note 10 Deal: BOGO at Verizon!
  1. Shargeel Kiani's Avatar
    Im using nexus 5, after the update to lollipop( which i updated 15days ago) ,my battery timing had increased... But recently something bad happened and my battery life is decreased to great extent, any solutions?
    11-22-2014 12:56 PM
  2. Golfdriver97's Avatar
    Have you tried a reset?
    11-22-2014 01:32 PM
  3. Shargeel Kiani's Avatar
    How to do a reset?
    11-22-2014 03:28 PM
  4. Shargeel Kiani's Avatar
    I turned off my phone, than switched it on, but still havin same issue
    11-22-2014 03:39 PM
  5. Golfdriver97's Avatar
    A reset being completely reset the device so you have to set it up all over again. Back up any files you don't want to lose, and then in Settings, there should be a backup and reset option. Click on that.
    daihard2008 likes this.
    11-22-2014 04:08 PM
  6. daihard2008's Avatar
    This is probably a basic question. When you do a factory reset, will it erase the user data stored on the /sdcard partition as well?
    11-22-2014 04:16 PM
  7. Golfdriver97's Avatar
    In my experience, it has gone both ways. I have had data wiped, and not. I always go under the assumption that data will be lost when a reset is done.
    Edit: and external card should be fine, but when I had devices that took them, I always unmounted them just in case.
    11-22-2014 07:12 PM
  8. Shargeel Kiani's Avatar
    Well its working fine nw after full charge and doing some settings. Actually i had set backlight time fr 5min, now i set it fr 15sec, an battery graph is bck to normal.
    11-23-2014 12:49 PM
  9. daihard2008's Avatar
    That makes me wonder if the user data on the "internal" storage mounted as /sdcard/ will be wiped as well. Even though it is truly an internal partition, its name suggests that Android may treat it like an external one. Any thoughts on this?
    11-23-2014 01:16 PM
  10. Golfdriver97's Avatar
    I would have thought the personal data should be safe. But then again, I think the last time that happened was on my S2 which was partitioned in such a strange way.
    11-24-2014 09:10 AM
  1. major help need back a deleted pic
    By bjballar41 in forum LG G3
    Last Post: 11-25-2014, 03:23 AM
  2. How do I recover my password for my lock screen?
    By ronin425 in forum Samsung Galaxy S5
    Last Post: 11-22-2014, 07:36 PM
  3. Can't find the update. Help?
    By Pre-dawn raid in forum Google Nexus 4
    Last Post: 11-22-2014, 01:03 PM
  4. Why can't I get Angry Birds to run on my Motorola Xoom?
    By papaformigas in forum Android Apps
    Last Post: 11-22-2014, 06:03 AM
  5. Replies: 3
    Last Post: 11-22-2014, 05:32 AM
