1. digitalangel's Avatar
    No "wifi" Setting for Smart Lock. Boooo. Silly to miss it out.
    Trying bluetooth and all set up fine, but I'm bound to forget about switching it on. Are there any ways or apps that can do do, maybe based on my home wifi or times?
    11-26-2014 06:23 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Your Google Play Services probably hasn't been updated to 6.5 yet (which should happen some time soon). On 6.5, you get an additional option in Smart Lock to choose a Trusted Place, which is determined by the Location service. I have my Home set as a Trusted Place.
    11-26-2014 03:28 PM
  3. radicchio's Avatar
    Have you done any testing to see how far from home you can get before the phone locks? Just wondering what the range of this is when based on GPS.
    11-26-2014 07:46 PM
  4. AZgl1500's Avatar
    MacroDroid can do that for you, it is very versatile. Sure wish I owned stock in their company.
    * MacroDroid - Device Automation - Android Apps on Google Play
    11-26-2014 08:45 PM
  5. B. Diddy's Avatar
    No, I haven't. It's supposed to stay unlocked within a radius of 100 meters, which is pretty broad. If you don't have the actual GPS on (i.e., you're on battery-saving location mode, using only wi-fi and mobile data to estimate your location), then location could be off by more than 100 meters, especially if your mobile data signal isn't great.
    11-26-2014 11:50 PM
  1. Why is my wifi slower on my Note 4 than all other devices?
    By ElvDaKing in forum Ask a Question
    Last Post: 01-21-2015, 12:09 AM
  2. Switch to LG G3 ?
    By grumpygramps1 in forum LG G3
    Last Post: 12-08-2014, 07:03 AM
