1. stuarta99's Avatar
    Anybody know of any decent battery apps or widgets for Android 5. I've tried the app by kroegerama but it's very small to read and not sure if anybody has tried anything better
    11-27-2014 05:04 AM
  2. Battleship's Avatar
    I use Battery Widget Reborn. Lots of settings, gets the job done very nicely.
    11-27-2014 04:37 PM
  3. stuarta99's Avatar
    Ok does that definitely work on Android 5 lock screen? I'll have to see if I can find some screenies before I buy. All others I've tried work when unlocked but not on the lock screen
    11-27-2014 04:48 PM
  4. daihard2008's Avatar
    You can try it quickly and ask for a refund if it doesn't work the way you want it to. I believe you've got 15 minutes to decide. Not much time, but should be enough for what you need to make sure, IMO.
    11-27-2014 07:56 PM
  5. vividrich's Avatar
    I've been using "battery percent for kitkat/L" since kitkat. Works great, even better on lollipop.
    Posted from my Nexus 7 2013 via Android Central App
    11-27-2014 09:14 PM
  6. MetalMike901's Avatar
    Same. I've used BWR for a long time and with Lollipop it's still working great. Great app!
    Posted via Android Central App with my Lollipop Nexus 4 on Cricket
    11-27-2014 09:34 PM
  7. stuarta99's Avatar
    Just installed it, well the free beta version that came out 19th November and although the status bar on unlock is nice, still doesn't provide status bar on lock, just the bar notification
    11-28-2014 03:21 AM
  8. tonyr6's Avatar
    I use power toggles. You can see here by my screenshot that it shows the battery percentage on the lock screen.
    11-29-2014 12:36 AM
  9. Battleship's Avatar
    It does. There's a free version, too: my bad for not linking to it. You can see from the screenshots that the battery percentage is on the lock screen and that it can be expanded to show you whatever information you set up to see. I'm not sure if you can do both things with the free version, but you definitely can with the pro.
    11-29-2014 06:29 AM
  10. stuarta99's Avatar
    Yep sorry I did see it with the notification but was hoping to get it in the status bar like I had before. Just updating the wife's and she's saying the same "oh I don't like that, I want what I had before". Guess we just being fussy lol. I have however just re-enabled my Settings Extended to show battery indicator and guess I'll have to deal with that for now
    Attached Thumbnails Lock screen battery indicator-uploadfromtaptalk1417301179837.png
    11-29-2014 05:46 PM
  1. Why does my Galaxy Note 4 screen sometimes not respond to touch?
    By SalGuarnera in forum Samsung Galaxy Note 4
    Last Post: 03-27-2016, 08:23 AM
  2. Does Keeping OK Google Always OK affect Battery Life
    By Jason Rosenberg in forum Google Nexus 6
    Last Post: 11-27-2014, 07:56 AM
  3. Why does my Note 4 screen have a wake up lag?
    By hormelonabun in forum Samsung Galaxy Note 4
    Last Post: 11-27-2014, 07:50 AM
  4. Should I drain my Droid Turbos battery on first charge?
    By Seremedy in forum Motorola Droid Turbo
    Last Post: 11-27-2014, 06:29 AM
  5. Batteries are on my list this Holiday
    By bienew in forum Samsung Galaxy S5 Accessories
    Last Post: 11-26-2014, 11:30 PM
