I forgot the APK name that did this for KitKat but I specifically remember you could install this little patch and it simply exposed the built-in battery level in the notification bar. Is there such a thing on L?
Thanks
Thanks
This is the app your looking for: https://forums.androidcentral.com/e....kroegerama.android4batpercent&token=4ghCBClGI forgot the APK name that did this for KitKat but I specifically remember you could install this little patch and it simply exposed the built-in battery level in the notification bar. Is there such a thing on L?
Thanks
This is the app your looking for: https://forums.androidcentral.com/e....kroegerama.android4batpercent&token=r5XVtpud
Thankfully, on Lollipop, you can the percentage even before it has drained past ~40%!
