1. vosamour's Avatar
    Nexus 5 - Lollipop update
    My phone is plugged into my pc and charging and i'm using it while plugged in and the battery life goes down. What the hell??
    Anyone?
    *yes i'm using the CABLE that came with the phone.
    12-17-2014 12:36 AM
  2. mbryanr's Avatar
    A USB port is limited to 500mA,which could explain the battery drain during use and charging. I know that my S5 would drain based on if I was using it.
    The wall plug? I dunno. What plug are you using? That is what drives the capacity, not the cable...
    12-17-2014 03:37 AM
  3. N4Newbie's Avatar
    See my comments about USB port charging here http://forums.androidcentral.com/goo...ml#post3792567
    vosamour likes this.
    12-17-2014 07:46 AM
  1. Wireless Charging Benefits?
    By joediver in forum Samsung Galaxy Note 4 Accessories
    Last Post: 10-19-2015, 04:50 PM
  2. Replies: 20
    Last Post: 03-16-2015, 12:23 PM
  3. does your OEM wall charger charge correctly?
    By donebrasko in forum Samsung Galaxy Note 4
    Last Post: 12-17-2014, 04:17 PM
  4. cell phone bands
    By dougie1792 in forum Samsung Galaxy S5 Rooting, ROMs & Hacks
    Last Post: 12-16-2014, 11:15 PM
  5. Replies: 0
    Last Post: 12-16-2014, 10:49 PM
