1. sprocket42's Avatar
    Hey everyone,
    Before I upgraded to 5.0.1, my exchange (MS Outlook) contacts used to sync with my car's bluetooth without any problems.
    But after the upgrade, Exchange contacts are not shared with my car. Anyone else experienced this or does anyone have a solution?
    Aditional info:
    - Gmail contacts and Call history are synced without any problems.
    - I created a new Exchange contact via phone itself just to see if problem was with existing contacts which were created on Outlook PC. - no avail.
    - I downloaded an app called Bluetooth Phonebook, which apparently uses its own PBA profile. And it solved the problem. However I prefer a permanent solution and not having an app installed.
    - I tried clearing all Data and Cache of Bluetooth Share app as well as Contacts and Gmail Contacts.
    12-18-2014 03:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Open your People app, tap Menu, then Contacts to Display. Instead of "All Contacts," tap "Customize." Now tap all of the contact groups you want displayed. See if that helps--it's what I had to do with my Nexus 5.
    sprocket42 likes this.
    12-18-2014 09:15 PM
  3. sprocket42's Avatar
    Yup, it did the trick. Thanks a lot!
    B. Diddy likes this.
    12-19-2014 01:00 PM
  1. Replies: 1
    Last Post: 12-18-2014, 09:17 PM
  2. Replies: 1
    Last Post: 12-18-2014, 09:24 AM
  3. firmware upgrade prompt - but my S4 mini came with 4.4.2
    By tripton in forum Samsung Galaxy S4 Mini
    Last Post: 12-18-2014, 05:56 AM
  4. Can I use a room air purifier inside my car ?
    By snowpiercer in forum Autos
    Last Post: 12-18-2014, 02:53 AM
