1. Tatooine_Star's Avatar
    My Nexus 10 has updated to android 5.0.1, and now the volume buttons on the edge of the device have reversed, so the volume up button now turns the volume down and vice versa. Can anyone help?
    12-24-2014 06:06 AM
  2. srkmagnus's Avatar
    Have you tried a factory reset? I'd give that a try since you just updated - hopefully that fixes the problem.
    12-25-2014 10:56 AM
  3. Tatooine_Star's Avatar
    Have completed two separate full factory resents, and the volume button issue is still there.
    12-28-2014 05:15 AM
  4. DLK1's Avatar
    Maybe you are holding your device up side down
    12-28-2014 08:53 AM
  5. Tatooine_Star's Avatar
    Maybe, but that would mean that in portrait mode the power and volume buttons would be in the bottom left hand corner, is that intended?
    12-28-2014 09:35 AM
  6. DLK1's Avatar
    I just went online and looking at the manual it shows the thing in landscape mode and the power button is on the top row. The volume is to the left of that, then the microphone and front facing camera in the center.
    12-28-2014 06:51 PM
  1. Why is my Nexus 10 volume button have reversed functions?
    By Tatooine_Star in forum Google Nexus 10 Tablet
    Last Post: 12-28-2014, 10:39 AM
  2. Ola! i run on Moto G, window 7
    By 8008s in forum New to the Forums? Introduce Yourself Here!
    Last Post: 12-25-2014, 08:27 AM
  3. How do O delete pics without any traces in Android?
    By Sushmitha S in forum Ask a Question
    Last Post: 12-24-2014, 10:37 AM
  4. Why am I not able to Switch on my Nexus 5 device?
    By kunal gaddhyan in forum Google Nexus 5
    Last Post: 12-24-2014, 04:32 AM
