1. Geodude074's Avatar
    Anybody else experiencing extreme lag and stuttering while entering text?
    It doesn't matter which app I use, the lag and stuttering is there. I can easily enter more letters than what appears on the screen. It's like the OS is struggling to display the letters I enter.
    This makes my phone nearly unusable for daily things. Texting, emails, web browsing - can't do any of them efficiently. I'll be rolling back to KitKat if I can't find a fix.
    Found a thread elsewhere where people talk about this issue:
    https://code.google.com/p/android/is...etail?id=80637
    01-01-2015 03:15 PM
  2. Rukbat's Avatar
    Is there any app Lollipop doesn't have some issue with? I haven't seen any post saying that Lollipop makes any particular app run better - only the ones it kills. And not just on one model phone - on many different makes and models.
    Lollipop the Android Killer.
    01-01-2015 04:00 PM
  3. N4Newbie's Avatar
    You don't say if you are using the stock keyboard.
    What device are you using? It is more than likely that you have an incompatible app installed.
    01-03-2015 01:25 PM
  4. Geodude074's Avatar
    I was using the stock keyboard on a Nexus 5.
    I switched to Swiftkey and my issues went away.
    This morning I deleted the cache from Google Search while doing something else unrelated, which resets the settings on my phone such as what icons/widgets go where and what keyboard to use. Somehow that seemed to resolve the issue as well! I'm now back to using the stock keyboard with no lag.
    01-04-2015 07:46 PM
  5. ptkelly's Avatar
    Imagine that. People don't post to say they use an app that doesn't conflict with Android 5. Okay, I have an Oxford English Dictionary, an Oxford Spanish dictionary, I use the Google Keep and Calendar apps. I use the Kindle app a lot. YouTube, a currency converter, and an app that has Spanish verb conjugations. And, Google maps.
    I've tried other apps that worked fine but that I simply didn't need. Oh, and I have a weather app with a widget running. Works fine.
    People tend to post problems. People tend not to post everything that isn't a problem.
    As to the OP, I clearly don't type at the speed the Geodude does but I text, make calendar entries, make lists for Keep and all using the stock keyboard, switching between English and Spanish, and have no problem with lagging or stuttering.
    01-05-2015 06:13 AM
  6. chezm's Avatar
    Ive experienced the lag input while typing using the Google Stock keyboard, whats weird is Lollipop has gradually got worse than when i first installed it...that includes the battery which has gotten worse too, as well as lag in general. No new apps installed, already wiped cache partition and it didnt help.
    01-05-2015 11:03 AM
  1. Is there a texting app to replace my native messaging app?
    By vkdelung in forum General Help and How To
    Last Post: 01-06-2015, 12:51 AM
  2. Text integration through bluetooth not available?
    By Marjorama in forum Samsung Galaxy S5
    Last Post: 01-02-2015, 08:56 AM
  3. Receiving texts on my iPhone instead of HTC?
    By mfarrukh in forum Ask a Question
    Last Post: 01-01-2015, 05:22 PM
  4. Can not receive pictures through text
    By Chris Yokiel in forum Ask a Question
    Last Post: 01-01-2015, 03:24 PM
  5. Samsung Galaxy Note 4 Sprint texting issues right now error 107
    By jordo487 in forum Samsung Galaxy Note 4
    Last Post: 01-01-2015, 12:15 AM
