1. Advaitom's Avatar
    Hi All, I'm using a Nexus 5 not rooted with Lollipop 5.0.1. On KitKat I used an app to enable wifi unlock and it was great. Apparently Lollipop breaks that capability and (from what I can see) no wifi unlock apps work with unrooted Lollipop.
    Is that true? Has anyone found a way to enable wifi unlock on Lollipop without rooting? If yes, let me know.
    I don't want to root my phone. Thanks!
    Advait
    01-13-2015 06:52 AM
  2. UJ95x's Avatar
    Not sure what you're asking. What do you mean by WiFi unlock?
    01-13-2015 11:31 PM
  3. Advaitom's Avatar
    I thought "Wifi Unlock" was a term in common usage. Perhaps not. It means that when my Nexus detects my home wifi signal it automatically stops requiring a PIN, Password or Pattern Lock. When I leave my home wifi then my Nexus automatically goes back to requiring a PIN, Password or Pattern Lock.
    I found an app yesterday called "Smart Unlock" that does this. So the problem is solved. How do I mark a thread as solved?
    Thanks,
    01-14-2015 01:40 AM
  4. UJ95x's Avatar
    Thanks,
    Ah. Yeah, I've only seen it referred to as smart unlock or trusted WiFi/bluetooth.
    No need to mark as solved. Since I have replied it will no longer show up as unanswered. Glad you were able to solve the issue
    Sent from my Galaxy S4 running Lollipop 5.0.2
    01-14-2015 09:22 AM
  1. Replies: 9
    Last Post: 01-18-2017, 04:03 PM
  2. How its possible Android tv Box 336mb ram?
    By Azuldefundo Portosempre in forum Memory (RAM)
    Last Post: 02-25-2015, 07:47 AM
  3. Finally got a Pocket Wireless Car Charger for my Nexus 6!
    By sigma24 in forum Nexus 6 Accessories
    Last Post: 01-16-2015, 08:18 PM
  4. Replies: 3
    Last Post: 01-13-2015, 09:24 AM
  5. kitkat had more brightness then lollipop
    By Lasha Vachadze in forum Google Nexus 5
    Last Post: 01-13-2015, 06:40 AM
