Can I get some help with Lollipop vs Asus tf300t?
Peter van Eijsden
I just got installed Lollipop 5.0.2 on my ASUS pad TF300T automatically and have the following problems now.
1. Can't send to Google LIve, There is no internet connection from there, I looked at the help and found that i must open port 5228, but my security says that it is an unknown and forbidden port.
2. I DONT HAVE THE Google Mail icon, my accounts are registered in the pad but no sync.
3. I miss the icon vor the keyboardaccu in the right upper corner.
Someone who can help me???
Peter (71yr)
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,541
4,675
113
Re: Lollipop vs Asus tf300t
Welcome to Android Central! What do you mean you got it installed automatically? The last I knew, the TF300T was stuck on 4.1.2, with no plans for further official updates. I'm assuming you flashed a custom ROM, correct? Which one was it?
Not sure what you mean by Google Live. Do you mean Google Now?
Laila Nance
