1. abdsam's Avatar
    I updated my nexus 4 to android lollipop but it is not the same as in nexus 5, different animations are missing. for eg the app tray has black background etc
    01-28-2015 10:50 AM
  2. Rukbat's Avatar
    Redo the update on the 4 (you may have to get your carrier to do it). The Android update method leaves a lot to be desired, including the possibility of errors that go undetected by the update. (And there will be differences between phone models - each update is written for that phone, it's not the same update for all phones.)
    01-28-2015 11:01 AM
  3. Mcwong's Avatar
    You will get the white background if you switch to Google Now launcher. The original launcher has black background
    02-03-2015 10:34 AM
  1. Exchange ActiveSync on Nexus 6
    By taappel in forum Google Nexus 6
    Last Post: 02-04-2015, 09:32 AM
  2. Why does my HTC M8 appear as CDRom in Windows XP?
    Last Post: 01-28-2015, 06:05 PM
  3. My cell says window limit reached, how do I remove the limit?
    Last Post: 01-28-2015, 11:27 AM
  4. Replies: 1
    Last Post: 01-28-2015, 11:19 AM
  5. Why is my phone locked on the Google screen?
    Last Post: 01-28-2015, 10:44 AM
