02-13-2019 03:38 PM
170 ... 567
tools
  1. Chode Node's Avatar
    Sorry for the older post. What worked for me was getting the Trusted Place to go as a set of coordinates rather than a street address. I did this by:
    1) Setting Location method to Wifi and Devices (option that doesn't use GPS)
    2) Going into Trusted Locations
    3) Add location
    4) Grant location permission, which turned GPS on, and showed coordinates rather than an address (I'm guessing not enough time to localize to a real address)
    5) Can then leave Location setting with GPS on.
    My trusted places shows my Home address and the coordinates associated with my home address. Have done this on two phones and it seems to work.
    04-16-2016 10:08 PM
  2. Arcendus's Avatar
    Chode, you glorious internet commenter, I think this did the trick!
    Nexus 6P, Android 6.01, rooted and xposed.
    06-27-2016 03:14 PM
  3. amoralis's Avatar
    I found a 100% solution (Note 4 with Gear S)
    It's all about device administrator apps.
    I had exchange client got there and then it got blocked.
    Once removed works fine on spot.
    I'm lucky, sure you're too - give it a try
    06-27-2016 05:21 PM
  4. jsarino's Avatar
    I bumped this up just to say that Chode Node's suggestion works for the Nougat OS as well.
    02-10-2017 01:53 PM
  5. Ryououki's Avatar
    Just wanted to let everyone know I tried all the methods in the thread but was not able to get trusted locations working on my Lenovo Phab 2 Pro. I gave up and accidentally fixed my issue. I powered off my Phab 2 Pro and moved my SIM card to another phone to test it out for a few minutes and needed info off my Phab 2 Pro, so I booted it up without the SIM card and noticed the trusted locations was working again. I powered off the Phab 2Pro, put the SIM card back in, booted it back up and location services are still working correctly again.
    Just thought I'd share for anyone having the same issue and the previous methods didn't fix it.
    TC Edwards likes this.
    02-17-2017 04:05 PM
  6. traceytaylor's Avatar
    Um, WHAT? Care to clarify?
    03-28-2017 07:35 PM
  7. PKerrivan's Avatar
    I've noticed a similar problem from exchange emails being signed in, they require device administrator access and will sometimes force you to change your screen lock method as well.
    I had my school email account signed in to the gmail app and could not use a pattern to unlock, and my roommate also had a problem with using a pattern when his work email was signed in.
    Problem doesn't seem to occur if you use a third party app to access the email account. I used Boxer to get around it.
    03-28-2017 08:12 PM
  8. jemerson1978's Avatar
    On my phone I had same problem. I noticed if I go to add new location when I'm at home it shows address already saved. But when I zoomed in it changed to a different location in my street. I saved this address. Then went back in and zoomed in again and gave me another address. Also saved it. Did it about 5 times and different addresses in my street. I've saved them all and now it works perfectly at home. Hope that helps.
    04-30-2017 12:20 PM
  9. RK928's Avatar
    Mine has been broken for a while also on my Moto X PE. What I don't understand is why can't we just set up the local wifi connection as a trusted device? I can do it for a Bluetooth and NFC connection, we should be able to simply set a wifi connection also.
    07-06-2017 10:01 AM
  10. iAmApathetic's Avatar
    I signed up just to pass this along...
    This has been bothering me for a long time and I really hope I'm not speaking to soon, BUT... I think I found a solution, as obscure as it seems:
    I Re-calibrated my compass and instantly location based Smart Lock is working again.
    Edit: I also have my home location from Google Maps turned off in smart lock settings.
    08-02-2017 08:31 PM
  11. iAmApathetic's Avatar
    So, I had it working at work, but not at home.
    The weird thing now... I connect my Logitech Bluetooth keyboard that is set as a trusted device and if I wait long enough, I can actually see the lock icon change to unlock.
    Seems to me this is only an issue with locations....
    Like others, I wish I could set wifi as a trusted source.
    08-15-2017 09:19 PM
  12. iAmApathetic's Avatar
    I put a shortcut to maps so when smart lock wasn't working at home I could check it. This time, I checked maps right after smart lock wasn't working and Google Maps shows that I'm about 3.5 km away from my home. I took a screenshot of this location, then found the address and added it to my trusted places. Now that it's added to trusted places, I can get into maps quickly, and I can watch my location flip back and forth between these two places.
    That's really strange. I guess I'll be able to see if this location is consistent over the next few weeks...
    08-28-2017 12:20 PM
  13. Droidsgirl's Avatar
    This happens to me once in awhile. Thought it was my phone, but actually it was the google maps app.
    So now when this happens I open the map app and "drive" home by walking around house til the app shows I have arrived!
    Hope this helps.
    10-30-2017 11:18 AM
  14. s004kcg's Avatar
    I have a pixel xl and this feature stopped working for me at the last update. I was messing around and nothing here worked ...but... i got it to work by going to Security & location---> Apps with usage access and removing Google Play services usage access permission. so far it has worked and no issues ... yet
    bobi666 likes this.
    12-18-2017 08:06 PM
  15. Citizenbrock's Avatar
    I was fed up and tried everything. I found a work around. Set up multiple location in your home and around your house. Now it Works. Maybe this is not an elegant fix, but it has been working for me for over a month. Good luck.
    03-30-2018 02:13 PM
  16. GeoffNET's Avatar
    Like many here, I've tried various fixes with temporary success. But I'd like to add one thing that might help:
    If, like me, you're still kinda using your old phone (as a media player, etc.) and it has Location turned on, turn it off. Or even, turn the whole phone off. After doing this, my new phone has yet ask me for my password when I'm at home.
    My thought is that, since both devices are signed in under the same Google account, they may be trying to send simultaneous signals claiming "I'm here!" And if these two signals are far enough apart, the margin of error on my exact location has to be big enough to include both, which could put me "potentially" outside my trusted place.
    Except that it seems to forget overnight (after 4 hours of inactivity), but after leaving home and coming back, it remembers on its own. If this happens consistently, I will try loading an app that checks my location (like Transit, Maps, etc.) and seeing if it refreshes automatically.
    Note: Sometimes my phone takes a few minutes to realize I'm in a trusted place, but after turning off my old phone, I have yet to resort to "clearing cache" or "toggling location for Google Play Services".
    04-09-2018 04:18 PM
  17. GeoffNET's Avatar
    Update:
    I let my phone stay inactive overnight and when I woke up, it asked for my fingerprint, as expected. Gave it a few minutes to see if it realized I was in a trusted place on its own -- it did not. Then, without leaving home, I loaded Maps (which gets my location) and then exited, and tested the Smart Lock again. It still asked for my fingerprint.
    Combined with previous evidence, this seems to indicate it may just be that Smart Lock needs to request its own location refresh after the 4-hour inactivity period. My old phone (LG G4) did that on its own; I remember seeing the location icon appear briefly right after using it first thing in the morning.
    I will try to send this feedback to Google via an appropriate method.
    04-10-2018 11:55 AM
  18. Kulvinder Jabble's Avatar
    After update to 8.0, my trusted place (home) on my Galaxy Note 8, doesn't work! Fine before!!!
    04-13-2018 02:42 AM
  19. Mike Demosthenous's Avatar
    If you leave your trusted location and then return it will be automatically enabled
    Update:
    11-09-2018 01:17 PM
  20. kayemh's Avatar
    i created an acct just to thank Chode Node for instructions that actually work.
    02-13-2019 03:38 PM
170 ... 567
  1. When my screen is unlocked why doesn't anything show?
    Last Post: 03-08-2015, 01:34 AM
  2. Replies: 2
    Last Post: 03-07-2015, 12:47 PM
  3. Replies: 2
    Last Post: 03-07-2015, 08:56 AM
  4. Replies: 1
    Last Post: 03-07-2015, 08:52 AM
  5. google play not working/android.media.process.stopped
    Last Post: 03-07-2015, 08:51 AM
