Can I get some help with a few issues with MS Lync 2013 and Lollipop?
A
AC Question
issues with MS Lync 2013 and Lollipop? Wont even open App?
Apparently since installing Lollipop, Lync2013 will not open. Whenever I attempt to open the app, it appears to try to start and then just closes. Anyone else experience this? Know of any fix? Thanks!
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,536
4,673
113
Re: issues with MS Lync 2013 and Lollipop? Wont even open App?
Welcome to Android Central! There are a number of similar complaints in the app reviews on Google Play. Have you already tried Clearing Cache/Data from the Settings>Apps​ menu?
