1. slave's Avatar
    for one, I can't get the adb command to work. The cmd doesn't recognize it. I then went and got Wug. It gets to the point where your phone resets, and the Android is on his side, the phone then disapears from my device list in windows. Wug then can't find it, and no update....
    Why is this so difficult? How do keep it showing up in the list? I wish Google wouldn't suck so bad with these updates.
    Very frustrated here, thanks for any advice.
    03-14-2015 09:18 PM
  2. slave's Avatar
    To add, when it goes to recovery mode, there is no device to update the driver to, it is simply gone from the computer until I reboot
    03-14-2015 09:25 PM
  3. slave's Avatar
    no one? This is frustrating. Very frustrating. I have searched all three forums, and each one says there should be a yellow explanation point, but there is not, as my drivers installed just fine.
    03-14-2015 09:57 PM
  4. slave's Avatar
    used a third party driver to trick it and used WUG.
    Note to all, just download Wug.
    03-14-2015 11:24 PM
  1. Does Dolphin Browser work on Nexus 6 running 5.1?
    By diesteldorf in forum Google Nexus 6
    Last Post: 03-16-2015, 11:07 AM
  2. Why can't anyone hear me when I use my wired headset on SG4?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 03-15-2015, 02:37 AM
  3. how i can re unlocked galaxy note 4
    Last Post: 03-14-2015, 10:42 PM
  4. I just got my phone 2 weeks ago,what can I do to fix it?
    Last Post: 03-14-2015, 07:08 PM
  5. Can a Cricket Samsung Galaxy S3 be switched to Straight Talk?
    By AC Question in forum Samsung Galaxy S3
    Last Post: 03-14-2015, 07:04 PM
