1. KRCsimple's Avatar
    Alrighty so here's the issue...
    I get in the car. I turn on my App Radio 3. I fire up the bluetooth on my Nexus 6 with Lollipop (5.0 and 5.1) and it connects fine (already paired). Phone and media both work.
    I turn off the App Radio 3. I turn it back on.
    The bluetooth auto connects. However it connects as PHONE only with "No Media" connection.
    It requires me to turn off the Nexus 6 bluetooth and turn it back on and it'll connect back with media just fine.
    This is an issue with Lollipop specifically, as with Kitkat on my Nexus 5 I never had this issue. Current iPhones connect and reconnect just fine with the App Radio 3.
    What could be the problem? And how do I notify google to potentially get this resolved?
    Troubleshooting:
    Updated from lollipop 5.0 to 5.1 firmware and it still has the same problem.
    Updated the App Radio 3 firmware from 08.02 to 08.05 and it still has the problem.
    Cleared android cache.
    Deleted the pairing many times and re-paired.
    All to no avail.
    03-21-2015 12:21 PM
  2. Rukbat's Avatar
    Wait for 5.1.1. Or 5.1.2. Or whatever number the one without bugs turns out to be.
    03-21-2015 01:11 PM
  3. KRCsimple's Avatar
    And just hope they fix it?
    Is there a way to submit a ticket to google or inform them of the problem?
    03-21-2015 01:14 PM
  4. DrunkFux's Avatar
    Hey, i just got an appradio 3 and am having the exact same issue with a Nexus 5 and a Oppo OnePlus...
    did you ever find a solution?
    08-14-2015 11:18 PM
  5. KRCsimple's Avatar
    Nope I never found a solution. Software updates didn't fix it.
    Your oneplus running lollipop? Considering you are using a nexus 5 and a oneplus - it's obviously not a Nexus 6 (2014) hardware problem, it's a lollipop problem.
    08-15-2015 12:00 AM
  6. treetopsranch's Avatar
    Note that Samsungs version of lollipop has disabled many third party blue tooth devices also. Especially the Note Pro 12.2.
    08-15-2015 11:01 AM
  1. No notifications on WiFi except hangouts?
    By kusabi in forum Android 5.0 Lollipop
    Last Post: 04-20-2015, 08:09 PM
  2. Unidentified "No" Icon on Upper Right Corner
    By snafudawn in forum Google Nexus 10 Tablet
    Last Post: 03-22-2015, 08:57 AM
  3. Why won't my Note 4 turn on?
    By dpgoose in forum Samsung Galaxy Note 4
    Last Post: 03-21-2015, 07:43 PM
  4. Remove apps from the sharing services list?
    By Jason Clishe in forum General Help and How To
    Last Post: 03-21-2015, 07:06 PM
  5. Replies: 0
    Last Post: 03-21-2015, 11:23 AM
