1. Mathieau's Avatar
    Hello, did you noticed the bug with manual exposure setting in the camera? If you set it (there is a dongle in the advanced settings) nothing happens! No more icon appears to adjust exposure while taking pics. And it seems that in all other apps (also manual camera, fv5 and similar that use the new APIs) the manual exposure has no effects.
    That's really annoying to me! I used the feedback link in the stock app to report it to google maybe if you'll do the same this bug will fix sooner
    03-28-2015 05:59 PM
  2. Mathieau's Avatar
    There is a bug report on google code. Maybe if put a star it can help. This is the link:
    03-29-2015 11:23 AM
  3. Mathieau's Avatar
    03-29-2015 11:23 AM
  1. Are You Having Rebooting Issues? Or Have You in the Past?
    By Raddichio in forum Google Nexus 6
    Last Post: 03-31-2015, 09:56 AM
  2. Replies: 3
    Last Post: 03-29-2015, 07:27 PM
  3. Can't move apps to SD after lollipop update and reset
    By andrewg13 in forum Samsung Galaxy Note 4
    Last Post: 03-28-2015, 06:26 PM
  4. text message in lollipop
    By n2468 in forum Moto G (2013)
    Last Post: 03-28-2015, 02:51 PM
  5. Can't open Word documents in Android lollipop
    Last Post: 03-28-2015, 01:29 PM
