11-10-2018 09:05 AM
55 123
tools
  1. Foques's Avatar
    Hi folks,
    My phone recently got the nightmare people call lollipop..
    While there are many annoyances with this release, I'd like to ask for help with one of them this time.
    How do I disable the "Batterycharged. Disconnect phone" notification?
    This notification is useless to me, and I want it disabled, but I can't seem to turn it off on my phone.
    It is an sprint's s5; not rooted.
    help?
    04-03-2015 04:06 PM
  2. mstrblueskys's Avatar
    This feels like a stupid question, but did you go into the battery settings? You should also be able to control notifications in your programs settings.
    04-03-2015 04:34 PM
  3. Foques's Avatar
    not stupid at all. But yes, I did go through all menus.
    The only one I can imagine would be suitable for this is in the battery app itself, but the show notifications box is checked AND greyed out.
    04-03-2015 05:51 PM
  4. ptkelly's Avatar
    My Nexus 5 with Android 5 does not give me a notice when the battery is full. I've had Android 5.0, 5.0.1, and now 5.1. None gave me a notice when my battery was full. So, I'm assuming it's not Android and is an added feature of your particular brand of phone.
    04-04-2015 02:53 AM
  5. DLK1's Avatar
    Sounds like some thing the S5 is doing, I to have a Nexus 5 and it does not notify me when it's fully charged.
    04-04-2015 10:04 PM
  6. JimSmith94's Avatar
    I'm on a TMO Note 3 and have the same frustration with the battery charged notification. I've seen this posted many times in many forums, so I don't think it's phone specific. It could be Samsung or TouchWiz, but I'm sure I've seen it reported for non-Samsung phones too.
    04-05-2015 09:37 PM
  7. DLK1's Avatar
    I have searched my Nexus 5 and can not find any notification for battery fully charged. The only time I every got a notification was when I had DU Battery Saver app installed, I have since uninstalled that app after trying it. That is why I though it was TW doing it.
    04-06-2015 11:00 AM
  8. JimSmith94's Avatar
    Battery fully charged doesn't show in the app list on my Samsung Note 3 either.
    04-06-2015 11:48 PM
  9. fotyc's Avatar
    I have the same question! Just got Lollipop on my AT&T S4 and kept it plugged in for download and install, and that notification blocked me from getting things at the top of the screen, I'd like to be able to acknowledge it and close it but I can't.
    04-08-2015 10:57 AM
  10. DLK1's Avatar
    I believe this may be a Samsung issue, I do not get that notification at all on a Nexus 5. So it must be a Samsung app or Touch Wiz. The only devices reporting this are Note3, S4 and the S5. Wonder if you would get more help over in the Samsung forum rather then the Lollipop forum.
    04-08-2015 12:38 PM
  11. fotyc's Avatar
    Thanks... but a quick google just showed me that it's also happening on some LG devices. Weird.
    04-08-2015 01:12 PM
  12. Foques's Avatar
    it is not. my coworker's Nexus does the same thing.
    04-08-2015 04:13 PM
  13. RogerCAMERON's Avatar
    Our two Samsung Note 3 s have started doing this since the lollipoop upgrade. Our faithful nightclocks can't supress the message at 2.00 in the morning!
    04-08-2015 04:22 PM
  14. JimSmith94's Avatar
    You can get rid of it by swiping it away like any other notification.
    04-08-2015 11:50 PM
  15. fotyc's Avatar
    I thought I had tried to do that and it wouldn't go. Anyone else?
    04-09-2015 08:40 AM
  16. Foques's Avatar
    you can, but it is a pointless notification.
    Janet Ray and KJ78 like this.
    04-09-2015 11:39 AM
  17. RogerCAMERON's Avatar
    We can definitely clear the message, just don't really want to at 2.00am when it lights the room up!
    04-09-2015 01:28 PM
  18. Janet Ray's Avatar
    My husband recently updated to lollipop and we're also seeing that dumb battery is full notification and it lights up the dam room at midnight or 2am and it's useless and apparently I am not the only one that can't figure out how to get rid of it. He has a AT&T samsun Galaxy S4
    KJ78 likes this.
    04-19-2015 09:11 PM
  19. JimSmith94's Avatar
    My brother just got the Lollipop update on his Verizon Note 3 and doesn't have the battery charged notification. His charge light just turns from red to green like it did on KitKat. He has OB6 vs. the OB4 I have on my T-Mobile Note 3, so maybe they fixed it in the newer release.
    04-20-2015 12:33 AM
  20. Cristin Oprea's Avatar
    I found solution. Just slide charged notification to right or left and dissapear.
    I hope I was helpful
    05-03-2015 05:36 PM
  21. JimSmith94's Avatar
    That's what everyone is already doing to get rid of it. The problem is how to keep it from showing up in the first place. Many people are being woken up by the light in the middle of the night when it reaches full charge.
    sherwood315 and KJ78 like this.
    05-03-2015 07:28 PM
  22. taaffee's Avatar
    My Samsung devices have done this since 4.0. I have my screen time out at 15 seconds so it turns off. As far as the middle of the night.....I just have my phone face down and don't see the light go on for that 15 seconds
    05-07-2015 12:22 PM
  23. JimSmith94's Avatar
    That's not what we're talking about either! In Lollipop, when the battery is fully charged, a white notification bar pops up at the top of the screen telling you to unplug the phone. It won't go away unless you either unplug the phone or swipe it away. That is what we're trying to keep from showing up.
    05-07-2015 05:20 PM
  24. DLK1's Avatar
    That is interesting, because I'm running Nexus 5 with Lollipop and I do not get any notification pop up telling to unplug the phone. Must be a Samsung thing only?
    05-07-2015 09:58 PM
  25. JimSmith94's Avatar
    My brother has a Verizon Note 3 on Lollipop and he says he doesn't get it either. That tells me that if it is a Samsung thing, there must be a way to stop it for the other carriers.
    05-08-2015 12:44 AM
55 123
  1. Replies: 2
    Last Post: 04-03-2015, 05:19 PM
  2. Replies: 2
    Last Post: 04-03-2015, 05:10 PM
  3. Why has my battery percent stuck when charging my Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 04-03-2015, 05:09 PM
  4. charging my Mega along with accessory battery inline?
    By GranPaSmurf in forum Samsung Galaxy Mega 6.3
    Last Post: 04-03-2015, 05:04 PM
  5. How do I make the sound better on my Samsung Galaxy S4 with beats?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-03-2015, 04:04 PM
