1. blahblah_gc's Avatar
    My G3 worked fine with KK, then Lollipop changed everything. No notifications with Wifi, battery drain and wifi slow with Xfinity Arris Modem. Did a factory reset, only fixed the battery drain.
    It is really NOT acceptable to reset your phone every time a system update is done. Can you imagine to reformat your HD, re-install OS every time you do a windows' update? Feel Lollipop is like Vista, hope google doesn't turn into Microsoft...
    04-26-2015 02:24 PM
  2. AndroidHabit's Avatar
    I just noticed a day ago that when I click on the data toggle switch it shows 4g LTE but the switch doesn't stay lit and texts don't download or able to send mms.
    The switch also will not turn off data once you click it on.
    I have to reboot my phone in order to turn off the data, it also only works sending data with google play no problem and my browser sometimes.
    This is a huge problem and I'm not liking lollipop at all right now.
    Anyone know how to fix this?
    04-26-2015 03:16 PM
  3. blahblah_gc's Avatar
    It doesn't matter how many "new" features Lollipop provides, if it can't even satisfy the most basic functions, what good does it do? The problems we are seeing are so easy to catch, I start wondering if Lollipop was being tested properly.
    04-26-2015 05:53 PM
  4. AndroidHabit's Avatar
    UPDATE:
    I got the data toggle switch to work now but not really sure what fixed it.
    If you are using an appops app make sure you allow important system items to "modify settings"
    I had some unchecked, I also uninstalled all xposed related things like deep sleep battery saver which might have caused a problem since third party apps can't control data anymore.
    Now I have another problem, somehow my APN settings got messed up and now that I got data toggle working my messaging app will still not download pictures.
    I manually entered AT&T APN information and it still doesn't work.
    Any help with this is appreciated.
    04-26-2015 06:52 PM
  1. LG G3 home buttons...
    By bfwaring in forum LG G3
    Last Post: 04-30-2015, 06:21 PM
  2. google messenger screen scrolls up after I text
    By Terrorizer in forum Google Nexus 5
    Last Post: 04-28-2015, 11:38 AM
  3. Replies: 2
    Last Post: 04-26-2015, 07:27 PM
  4. Where can I find the serial number on the LG Lucid 2?
    By AC Question in forum LG Lucid 2
    Last Post: 04-26-2015, 02:31 PM
  5. Will Lollipop fix Miracast to my Windows Wireless Adapter?
    Last Post: 04-26-2015, 01:18 PM
