I updated my Tmobile Galaxy Note Edge to Lollipop 5.01 and I'm getting both the battery drain bug (2% drain every 10 mins - wow!) and the overheating issues. Is the only way to fix this is to do a factory default/reset wipe?
I really rather would not because I have a number of customizations that are hard to put back on the phone including some specific ones from work...but if that is the only way to fix it I will do that...someone who has done the factory reset please advise if it truly did fix the battery problem. (Before I do it)
