1. Shane Loniewski's Avatar
    Help... new os is soooooo slowwwww data isn't working efficient, phone lags , apps close, only way to turn off my flashlight is to reset my phone... anyone help.? Besides factory reset.
    All help appreciated,
    05-08-2015 09:22 PM
  2. DLK1's Avatar
    This is something that you may not want to hear. However, if you check this forum you will see that a factory reset will resolve most of the problems with Lollipop upgrade. I always do a factory reset after a upgrade. You will need to backup anything you do not want to lose, data or apps.
    05-17-2015 10:40 AM
  1. Galaxy S6 Edge overheat
    By xtreme23 in forum Samsung Galaxy S6 edge
    Last Post: 12-09-2016, 06:55 PM
  2. Note 4 power sharing pop up
    By Rmedy21 in forum Samsung Galaxy Note 4
    Last Post: 08-18-2016, 09:53 PM
  3. Note pad apps
    By Kjthomas0724 in forum Samsung Galaxy Note 4
    Last Post: 05-09-2015, 09:32 AM
  4. My Gear S doesnt show clock when I turn my hand over....help?
    By Douglas Yarnold in forum Samsung Gear S
    Last Post: 05-08-2015, 09:23 PM
  5. What are battery_stats.txt notes?
    Last Post: 05-08-2015, 07:40 PM
