1. AC Question's Avatar
    I have had a Galaxy Tab S 10.5 for about 8 months. Fabulous device. Auto update sis on by default. 5 or 6 days ago I was prompted to install Lollipop 5.0.2, an 185Mb download. I promptly did so.
    Big mistake. I have 2 serious issues;
    1. battery drain makes it almost unusable. I can literally watch the meter drop with just plain internet browsing. It will drain maybe 15% or more in an hour
    2. I use Chrome as browser of choice. Now I get frequent "Aw Snap" freezes when I never had any before.
    I am sure I am not the only one. Hopefully someone can suggest some fixes for this buggy O.S. If I could revert to KitKat without a factory reset I would, I dislike this so much.
    All help gratefully accepted.
    05-12-2015 06:31 PM
  2. STARGATE's Avatar
    Hello John, have you done a factory reset?
    It is recommended to do a factory reset after a software update.
    Just remember to back up everything so you won't lose it.
    Sent From my Gold Platinum Galaxy S6 Edge
    05-12-2015 07:16 PM
  3. DLK1's Avatar
    I second that, the factory reset.
    05-12-2015 07:27 PM
  4. Davo21's Avatar
    Will that restore KitKat?
    What is the best way to backup all data, bookmarks etc etc?
    05-13-2015 06:01 AM
  5. macklearn's Avatar
    You want to say replace Lollipop with KitKat?
    05-13-2015 06:05 AM
  6. Davo21's Avatar
    What I am saying is that compared to the OS I had on the device, I find 5.0.2. a dog. Google suggests lots of people are finding the same. Unless a factory reset will resolve the 2 issues I posted about, I would prefer to consign this to the scrapheap and move to an OS that works. I assume a reset will revert to out of the box OS ie KitKat? I may be wrong. If it resets to Lollipop, I am happy to trial that again to see if issues are resolved - if they aren't I would want to replace the OS. Hope that makes sense.
    05-13-2015 04:34 PM
  7. STARGATE's Avatar
    No, you can't revert to KitKat. But still, you should give it a try and see for yourself if it'll work for you.
    05-13-2015 10:29 PM
  8. Davo21's Avatar
    Thanks for the responses.
    Can I ask specifically if anyone here on the forum has suffered the same problems and, if so, how they fared or resolved them?
    05-14-2015 01:08 AM
  9. STARGATE's Avatar
    Many people have experienced bad battery life after the update to lollipop.
    It actually happened to me with my Galaxy S5.
    But it starts getting better, especially after a reset.
    05-14-2015 04:38 AM
  10. Davo21's Avatar
    Thanks all.
    I tried a factory reset. Still unhappy with battery wear and frequent crashes on Chrome. Never had either before.
    Can anyone suggest how I can reinstall KitKat, which seemed entirely bug free.
    05-17-2015 06:19 AM
  11. DLK1's Avatar
    What make and model phone?
    05-17-2015 11:59 AM
  1. AT&T Tab S 8.4 Lollipop - Not yet released, waiting thread
    By Tersanyus in forum Samsung Galaxy Tab S 8.4
    Last Post: 06-17-2015, 12:33 PM
  2. The update today killed my G3 (AT&T).
    By frope01 in forum LG G3
    Last Post: 05-14-2015, 11:47 AM
  3. Replies: 8
    Last Post: 05-13-2015, 01:50 PM
  4. Battery dies - blue LED light
    By Brandwin in forum Samsung Galaxy Note 4
    Last Post: 05-13-2015, 09:02 AM
  5. Android Update Released for AT&T LTE
    By Shadowpdx in forum Samsung Galaxy Tab S 10.5
    Last Post: 05-12-2015, 05:24 PM
