1. Gordie Dickson's Avatar
    I recently upgraded my galaxy note 3 to android lollipop. Ever since the upgrade my battery is draining rapidly within 6 hours of a full charge.
    Any suggestions how to fix this?
    05-13-2015 08:39 AM
  2. dakshay95's Avatar
    Charge your battery up all the way to 100% then use it as you normally would. Once it reaches about 30 - 35% take a screenshot of the battery page (settings -> battery) and post it here.
    Does your battery discharge at a fast rate at night when you're sleeping?
    Gordie Dickson likes this.
    05-13-2015 09:09 AM
  3. KoNd2i0's Avatar
    Maybe you should make full wipe to have a clean rom
    05-13-2015 10:30 AM
  4. Gordie Dickson's Avatar
    Ok. Will give it a go
    05-13-2015 11:46 AM
  5. Gordie Dickson's Avatar
    I did a full reset to factory settings hoping it would cure it but unfortunately not
    05-13-2015 11:47 AM
  6. dakshay95's Avatar
    Post the screenshot as I had mentioned?
    Sent from my Moto G 2nd Gen using Tapatalk
    05-13-2015 11:48 AM
  7. Gordie Dickson's Avatar
    This is the screen shot
    Attached Thumbnails Why is my battery draining so fast?-screenshot_2015-05-13-23-26-58.jpg
    05-13-2015 05:30 PM
  8. dakshay95's Avatar
    Tap the graph and take one screen shot of the resulting graph as well please
    05-13-2015 09:14 PM
  9. Gordie Dickson's Avatar
    Ok
    Attached Thumbnails Why is my battery draining so fast?-screenshot_2015-05-14-11-08-59.jpg
    05-14-2015 05:11 AM
  10. dakshay95's Avatar
    Some app is keeping your phone awake all the time. That and your phone struggling to hang on to a mobile network signal are together causing the battery drain...
    Also turn off your GPS and WiFi/mobile network when you don't need them...
    05-14-2015 07:38 AM
  11. Gordie Dickson's Avatar
    05-14-2015 09:10 AM
  1. A gallery of night shots from my evening walk
    By StevenJ_AK in forum LG G4
    Last Post: 05-17-2015, 08:39 PM
  2. Battery estimate usage not showing
    By Taz89 in forum Samsung Galaxy S6
    Last Post: 05-14-2015, 07:58 AM
  3. Why am I not able to use my phone when on a call?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 05-13-2015, 07:27 PM
  4. Replies: 1
    Last Post: 05-13-2015, 05:17 PM
  5. Replies: 1
    Last Post: 05-13-2015, 03:24 PM
