1. Cameron Rowe's Avatar
    I have a BLU Studio X on NET10 (AT&T 4G service) My phone recently updated to lollipop, but ever since then, I can't send or receive MMS message. I called Net10 and talked to tech support and made sure all my APN settings are correct, but I still can't send/receive MMS messages. Is this a problem or a bug with the lollipop update for my phone???
    BoHo_Rex likes this.
    05-24-2015 08:20 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! I know you spoke to the NET10 people about it, but just to be sure, are these the APN settings they recommended? Phone Programming | NET10. Make sure you click the "If your carrier is AT&T" tab.
    05-24-2015 05:00 PM
  3. Ronald Gardner's Avatar
    I have a blue studio 6.0 and it prompts me to download the update and install if but when I'm finished I'm still on kit
    kat
    05-29-2015 12:04 AM
  4. B. Diddy's Avatar
    kat
    See your other thread for response: http://forums.androidcentral.com/and...ml#post4455599
    05-29-2015 01:19 AM
  5. 88Obz's Avatar
    I don't want to hate on a manufacturer here especially since I owned a Blu Life One X for a year before I accidentally smashed it - loved that phone (Blu has great tech support too FYI). But I bought the Blu Studio 6.0 LTE and had so many problems with it:
    . Music paused playing randomly (had same problem with my Life One X before it somehow stopped)
    . I had problems transferring files to and from PC
    . After a while the phone couldn't charge or transfer files any more! The USB port just crapped out. The phone WAS A WEEK OLD!
    I returned it. Got an Asus Zenfone 2 now. It's the same price same specs - Lollipop out the box - and its all good.
    Sergiusz Jasper likes this.
    05-29-2015 10:27 AM
  6. BoHo_Rex's Avatar
    I just a similar instance happen to me. Purchased a Studio X Plus last week. Wireless update to Android 5.0, and yesterday my MMS will not send or receive. (Straighttalk sim - from my old iPhone). Spoke with Straighttalk support for about 3 hours total yesterday trying to get it working - but to no avail. Tried 4 variations of the APN - and none work for MMS. Have also done a factory reset - which wipes my data - but still leaves me at Android 5.0. Have you had any luck getting it to work, yet? I'd like to go back to Android version that was stock on the phone... but cannot find any way of doing so...
    07-15-2015 12:32 AM
  7. Timothy Salib's Avatar
    I am having the same MMS issues with the studio 6.0 hd after the lollypop update does anyone have a fix yet or will we have to wait for a update from BLU
    08-04-2015 06:26 AM
  8. Jason Greenway's Avatar
    just run the update again thats what i did for my wife phone and all is well again.
    08-13-2015 03:04 PM
  9. Blizmobile's Avatar
    lollipop's design is not as good as kitkat's design (only on BLU studio) and i need help trying to downgrade the OS thank you!!!
    08-14-2015 04:28 PM
  10. SteveTHEDROVERYARDE's Avatar
    dont make the mistake , stay on kit kat , believe me . I have a blu studio 5 . i upgraded to lollipop and it is the worst mistake of the year for me. The phone sticks and laggs . the wifi keeps dropping out ot sometimes it just wont connect . Im now trying to see if i can reverse this but it seems not
    10-31-2015 01:27 PM
  11. B. Diddy's Avatar
    See response to your other thread: http://forums.androidcentral.com/ask...k-kit-kat.html
    10-31-2015 03:05 PM
  1. Replies: 9
    Last Post: 06-07-2015, 04:50 AM
  2. lollipop upgrade for Note Edge niggles
    By Chardmarky in forum Samsung Galaxy Note Edge
    Last Post: 05-24-2015, 10:35 PM
  3. Replies: 1
    Last Post: 05-24-2015, 05:50 PM
  4. Replies: 1
    Last Post: 05-24-2015, 08:08 AM
  5. Why doesn't my Google Chrome work after the Lollipop update?
    By AC Question in forum Android 5.0 Lollipop
    Last Post: 05-24-2015, 06:41 AM
