1. wordfool's Avatar
    I'm currently on 5.0.2 and after doing a full refresh and giving the phone a few days post-upgrade to settle down I'm getting absurd battery usage stats. Battery life itself is fine (after taming the runaway Google services), but at 50% battery the stats suggest my screen time is responsible for 3% (despite 4+ hours of SOT... hey, it's a Sony!), Android system 30% and K9 email for almost 30% (K9 kept the phone awake for less than 2 minutes, and Android System kept it awake for about 35 minutes). Those % figures are absurd and I now use GSam to see what's really happening. Needless to say, it gives far more believable stats.
    I have no rogue wake locks, I use Greenify to kill errant apps when not using them, wif-fi turns off when screen is off, and my wireless signal is green 90% of the time. Anyone experiencing the same, or know what's going on?
    06-02-2015 09:16 AM
  2. Rukbat's Avatar
    It's possible that one of your data files either got corrupt or is different after the update - which is why it's suggested that you do a backup, factory reset and restore after an update.
    06-02-2015 09:27 AM
  3. wordfool's Avatar
    I did that already -- updated from 4.4.4 to 5.0.2, rebooted, then immediately did a full reset/restore that wiped all data. I really don't want to spend hours doing that again unless I know it will solve this (and other) problems.
    06-02-2015 11:31 AM
  4. dakshay95's Avatar
    And on 4.4.2 K9 didn't cause you any issues?
    06-02-2015 07:58 PM
  1. bad battery life
    By BR34KF4ST in forum Samsung Galaxy S5
    Last Post: 06-04-2015, 05:57 AM
  2. Android System is taking up A LOT of battery...HELP
    By cjohn4043 in forum Moto X (2013)
    Last Post: 06-02-2015, 09:36 PM
  3. Newbie with a battery question
    By Allan Preston in forum Samsung Galaxy S6
    Last Post: 06-02-2015, 11:03 AM
  4. Nexus 5 turned off with full battery
    By bagou01 in forum Google Nexus 5
    Last Post: 06-02-2015, 10:05 AM
  5. Google Play Services taking too much battery
    By Philipp Yeo in forum Ask a Question
    Last Post: 06-02-2015, 05:39 AM
