01-06-2017 12:54 AM
33 12
tools
  1. debgram's Avatar
    It didn't fix my RAM problem
    08-23-2015 06:29 PM
  2. Nicholas Audy's Avatar
    My OPO Ram is usually full because of no reason..... 3 GB filled with things that i don't even know.... After 5.1.1 it seems that my ram only used 800 MB when not used at all/ after cleaning RAM.... Guess it's fixed for me!
    08-28-2015 05:03 AM
  3. Grudkin's Avatar
    In a nutshell, NO!
    I will never recommend Android to anyone, in fact I will recommend that anyone avoid buying anything running android!
    08-31-2015 10:14 AM
  4. Abdul-B's Avatar
    In a nutshell, NO!
    It is even worse on ios which makes old devices painfully slower to use after an upgrade.
    10-10-2015 01:39 PM
  5. Rajatdt's Avatar
    even after the update, my device is still suffering from the ram problem. The system is eating up all the memory and as a result the apps shut down themselves and the device becomes awfully slow. I dont know if their is any update coming in the future or if I am still stuck with this problem.
    10-24-2015 09:17 AM
  6. Bodeanicus's Avatar
    At least iOS devices aren't automatically abandoned after 1 generation.
    10-29-2015 08:15 PM
  7. jaleelhamid's Avatar
    Wrong lots of a droid devices are still supported the manufacturers stop supporting them not a Android for example Google's nexus devices the nexus 5 which is 2 year old generation device is still getting the news updates
    11-22-2015 03:47 PM
  8. Andu Abril's Avatar
    Not sure if it's because of the RAM leak but my phone has android 5.1.1 and it keeps on locking itself continuously. Sometimes it takes some minutes for the lockscreen to reappear, just suddenly leaving whatever app I'm using running on the background and showing just an empty desktop. If I move apps to the SD card it gets even worse. It can get locked up to once every five minutes.
    It's annoying AF.
    01-06-2017 12:54 AM
33 12
  1. Replies: 7
    Last Post: 03-15-2016, 02:39 AM
  2. Replies: 6
    Last Post: 07-28-2015, 10:15 PM
  3. Samsung G4 issue with powering on the phone, what should I do?
    By Danceswithhfire in forum Samsung Galaxy Note 4
    Last Post: 06-08-2015, 11:36 AM
  4. Replies: 2
    Last Post: 06-08-2015, 11:24 AM
