Mine is fine. The multitasking is a bit annoying after a few apps, but that's the case on every phone running Lollipop because of the memory leak
Sent from my Note 4 via Tapatalk
It will. Just a matter of when
Anybody with 5.1.1 can they confirm if it fixed the ram/memory issue? I have the s6 edge and I will close all apps and the minute I start playing jurassic world my ram is over 90% in red zone and I'm looking forward to 5.1.1 this month or next month.
In a nutshell, NO!
I will never recommend Android to anyone, in fact I will recommend that anyone avoid buying anything running android!
It is even worse on ios which makes old devices painfully slower to use after an upgrade.
At least iOS devices aren't automatically abandoned after 1 generation.
