1. Salil's Avatar
    Juice defender the battery saver app keeps crashing on lollipop. Any fix or alternative for this.
    06-15-2015 08:41 PM
  2. Crashdamage's Avatar
    Juice Defender is not good. Battery savers/optimizers are a waste of time. They usually actually use more power than they save.
    Uninstall Juice Defender and don't replace it with anything at all.
    Android since v1.0. Linux since 2001.
    troshs and Laura Knotek like this.
    06-15-2015 09:54 PM
  3. Fuzzfeatures's Avatar
    Actually I did an experiment over a period of a couple of weeks anticipation of getting a phone upgrade - one week I used my phone as usual with juice defender running and the second week i disabled it. I used it in much the same way each week.
    Juice defender did make my phone last longer - usually i got home from work with 20-30% more battery left when it was running. In the week that It wasnt running, I had to plug my phone in for it to last the rest of the evening.
    This of course will vary depending on how you use your phone. I work 12hrs a day four days a week and cant necessarily use my phone frequently at work. Juice defender saves battery life by switching off mobile data and wifi etc while the phone is asleep, only switching on at specified intervals to allow apps to sync etc. If you have your phone awake quite a lot, it wont save you as much battery power as it would for someone like me who has his phone asleep for up to 4 hours at a time. So i guess it works for some and not for others. Yes i know that it's easy to disable all the wifi,mobile data and bluetooth manually, but juice defender does this automatically(convenient for forgetful people like me) and it also allows apps to sync periodically (greate if you want to reply to messages reasoably promptly without having to faff around)
    +1 for Juice defender
    -1 for lollipop not playing nice with Juice defender
    07-27-2015 04:25 PM
  4. Salil's Avatar
    Yes Juice defender is definitely awesome with respect to power saving. Any fix for this issue?
    08-27-2015 12:18 PM
  1. Replies: 2
    Last Post: 09-19-2015, 09:09 PM
  2. How can I get my Droid Mini out of a bootloop?
    By Shane Lewandowski in forum Motorola Droid Mini
    Last Post: 06-18-2015, 09:12 AM
  3. Replies: 1
    Last Post: 06-18-2015, 09:06 AM
  4. Replies: 1
    Last Post: 06-18-2015, 08:48 AM
  5. Replies: 1
    Last Post: 06-16-2015, 08:08 AM
