1. rohan raverkar's Avatar
    I have latest Andriod OS with MotoG2, for last one month i am not able to download anything. No attachment from Gmail, Play store doesn't work. Download sign appears and then disappears without any error, its frustrating..!! I tried resetting my google profile, uninstalling Google Play updates...but nothing seems working, plz help...
    06-21-2015 10:44 PM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Dd you update to 5.0 Lollipop?
    06-24-2015 11:02 AM
  3. rohan raverkar's Avatar
    Yes, I did. it was working perfectly, but somehow its not working now. Not wokring through crome as well. Download icon appears and disappear immediately... Its really frustrating. I cleared all catche, uninstalled play store updates, clear data. Check for sufficient memory. Restarted
    06-27-2015 01:21 AM
  4. itguyjax8430's Avatar
    Last resort is a factory reset. There have been a lot of people having issues after they update to Lollipop. Most are cleared up when they do a factory reset.
    When you say you cleared all cache, does that mean you cleared the partition cache as well from recovery?
    06-27-2015 09:40 AM
  1. Replies: 2
    Last Post: 08-21-2015, 11:29 PM
  2. What should wifi settings be set at while at home with home wifi?
    Last Post: 06-22-2015, 01:45 AM
  3. Need help with date & time.
    Last Post: 06-22-2015, 12:03 AM
  4. Replies: 1
    Last Post: 06-21-2015, 10:10 PM
  5. Why are apps taking so long to download?
    By AC Question in forum Android Apps
    Last Post: 06-21-2015, 05:46 PM
