1. SamsungGuru's Avatar
    Hey Guys,
    I've had my Note 4 since first released. About 4-6 weeks ago I started noticing my haptic feedback (vibrations) not working anymore, so I checked to see whether power saving mode was active and it wasn't so I did a soft reset; didn't work and finally did a factory reset.... didn't work!
    I got the phone replaced with a brand new Note 4 but now for some reason the phone seems to be working but at times the vibration feel when pressing the menu and back button doesn't seem to be working consistently.
    My vibration is turned up completely and when it works its very strong and then all of a sudden the vibration goes to very weak and then non-existent. Has anyone experienced this and fixed it?
    My old Note 3 was perfect and didn't have this issue. I'm hoping someone has some tips to help fix this.
    06-28-2015 06:15 PM
  1. Would you still buy the Note 4 today?
    By Shepx13 in forum Samsung Galaxy Note 4
    Last Post: 07-24-2015, 03:03 PM
  2. Replies: 0
    Last Post: 06-28-2015, 02:26 PM
  3. Any suggestion on smartphones - Galaxy Note 4?
    By itsfighter in forum Samsung Galaxy Note 4
    Last Post: 06-28-2015, 01:02 PM
