1. DrNinjaman's Avatar
    Note 3 is SM-N9005 Qualcomm international version.
    Update was OTA official
    After the update, phone has never even detected my router's 5.0 GHz band, which worked just fine on KitKat
    Bluetooth problem initiated with my Gear dropping and not reconnecting without manual intervention. In the process of troubleshooting that, I forgot my Plantronic M90 headset which was working fine after the update and tried to re-pair the headset. Phone will not detect headset with the headset touching the phone. Does not matter if wifi is on or off, mobile data on or off, charging or not, visible to other devices or not. Phone will find the Gear Bluetooth signal, but that remains highly unstable also.
    I have cleared the cache. I have done a factory reset. I am decidedly unhappy that my headset no longer works with the phone, when it had been working just fine previously.
    07-04-2015 02:05 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Wi-fi, tap Menu>Advanced, and tap Wi-fi Frequency Band. Make sure it's set to Automatic, and not just to 2.4 GHz.
    Not sure what to do about the Bluetooth issues. You've already tried forgetting those devices, then re-pairing again?
    07-04-2015 05:59 PM
  3. zeus_bathala's Avatar
    I have the unit and the same problem. But until now I can not find a solution how to fix that problem.
    08-07-2015 08:55 AM
  1. Why won't any app work on my mobile?
    By AC Question in forum Android Apps
    Last Post: 07-04-2015, 06:07 PM
  2. Replies: 1
    Last Post: 07-04-2015, 03:39 PM
  3. 3D Themes Issue / Won't work
    By THE POTZ in forum Samsung Galaxy Note 4
    Last Post: 07-04-2015, 02:56 PM
  4. Droid turbo heats up after lollipop update
    By abd mohammad in forum Motorola Droid Turbo
    Last Post: 07-04-2015, 02:09 PM
  5. Replies: 1
    Last Post: 07-04-2015, 01:16 PM
