1. AC Question's Avatar
    I have a Samsung Galaxy Note Pro 12.2 with a Logitech keyboard. As you already undoubtedly know, immediately after the 5.0 auto-update the keyboard stopped communicating with the Galaxy. This is a huge inconvenience because I use the Galaxy in my business. When will a fix be available?
    07-14-2015 03:39 PM
  2. DudeManBud Man's Avatar
    Samsung is supposedly working on a fix or update to 5.0.2, but you could always do a revert back to 4.4.2. The only thing is that you'll have to do it as a firmware install with that particular ROM from Samsung and then you are back to square one and will have to re-install all your apps.
    Posted via the Android Central App (with my BlackBerry Passport)
    07-27-2015 04:49 PM
  3. jnaught's Avatar
    I gave up/broke down and bought the Samsung keyboard.
    07-28-2015 11:42 PM
  1. AT&T M9 Android 5.1 update rolling out 7/15
    By fernandezhjr in forum HTC One M9
    Last Post: 08-04-2015, 02:01 PM
  2. My xmbc/kodi download on android box won't work, why?
    Last Post: 07-15-2015, 12:25 PM
  3. How can I download the iTunes app for my Samsung Galaxy S-4?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 07-14-2015, 05:42 PM
  4. WiFi Issues
    Last Post: 07-14-2015, 05:41 PM
  5. Why is Android OS the main culprit?
    Last Post: 07-14-2015, 05:39 PM
