1. dudson86's Avatar
    hi i'd like to change sound of keyboard click in my wife samsung s4 i9505 lolipop. I have nokia lumia 640 and my wife likes sound of keyboard on that phone can i change it in some root mode or sth ?
    08-04-2015 04:30 PM
  2. Sergio Armenta's Avatar
    When you say change do you mean turn it off or find a different sound instead the clicky sound it makes
    08-04-2015 04:37 PM
  3. dudson86's Avatar
    yes, but i cant change to different sound, i can only switch it on/off in this android right ?
    08-04-2015 04:42 PM
  4. Sergio Armenta's Avatar
    Yeah. I haven't seen or heard about the possibility of been able to change the sound. I'm guessing maybe if you root the phone but not with the phones original software.
    Question: Do you still want to keep the sound just want to change to a different tone?
    08-05-2015 11:20 AM
  5. dudson86's Avatar
    Yes i want to do it if my phone will work after this operation
    08-07-2015 04:24 AM
  6. Sergio Armenta's Avatar
    You know I've I've never heard or seen anyone do this or asking about this. Hopefully someone that is familiar with rooting can help you with this, it might be the only way you might be able to change it, but I'm not familiar with rooting my Android. Sorry I couldn't help with this, some things are just better to leave them to the pros
    08-07-2015 11:57 AM
  1. Where is the reject call list on my phone?
    Last Post: 09-03-2015, 11:17 PM
  2. Replies: 1
    Last Post: 08-04-2015, 06:45 PM
  3. Can you encrypt Kies backups?
    Last Post: 08-04-2015, 06:44 PM
  4. Replies: 2
    Last Post: 08-04-2015, 04:37 PM
  5. How do I change the time/date/weather widget?
    Last Post: 08-04-2015, 04:23 PM
