1. AC Question's Avatar
    Before the upgrade from Kit Kat to Lollipop I had no problem with my blueyonder e-mail provider.
    Since the upgrade I keep on getting old e-mails from 2014 every day and it is a right pain to have to keep deleting them.
    Can anyone suggest a fix for this.
    Regards Alan.
    08-06-2015 10:34 AM
  2. Crashdamage's Avatar
    What email app are you using?
    Is this account POP3 or IMAP service?
    In your email app settings, is there an option to keep a certain number of emails or for a number of days of email to keep on the phone?
    Setting a fairly low number of emails or a number of days to keep might put a stop to the repeated downloads. Then again, it might keep downloading the same few emails over and over. Is it downloading the same emails repeatedly or different ones each time?
    Some email apps will let you set a number of emails, a few, such as Maildroid, can set a number of days to keep. My favorite email client AquaMail, will set a number of emails or a number of days, your choice.
    Of course, if you don't need all that old email, you could delete a bunch of it.
    08-06-2015 11:24 AM
  3. alan2273's Avatar
    It is a POP3 account.
    I have just been on to the Virgin Media account and seen there sere over 3000 e-mails held on there server going back to February 2014, so I have deleted the lot to see if that makes any difference.
    Deleting all those e-mails solved the problem.
    08-06-2015 11:37 AM
  1. T-Mobile Stagefright update -- version LYZ28J
    By quelquehomme in forum Google Nexus 6
    Last Post: 08-20-2015, 05:50 PM
  2. Received new update(08/06/15)
    By charliefromflorida in forum ASUS ZenFone 2
    Last Post: 08-14-2015, 12:33 AM
  3. Anyone having problems using Facebook; screen going black?
    Last Post: 08-06-2015, 10:24 AM
  4. Replies: 0
    Last Post: 08-06-2015, 10:12 AM
  5. Zooper Problem
    By millerwa76 in forum Samsung Galaxy Note 4
    Last Post: 08-06-2015, 10:00 AM
