1. Robster98's Avatar
    Tried everything to sort it out need help??
    08-22-2015 11:13 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    08-22-2015 10:52 PM
  3. Dominathan's Avatar
    This is after 3 fdrs and disabling lots of apps. I've tried everything. Nothing works for me.
    Attached Thumbnails Why does my LG G2 have rapid battery drain?-281.jpg   Why does my LG G2 have rapid battery drain?-283.jpg   Why does my LG G2 have rapid battery drain?-285.jpg   Why does my LG G2 have rapid battery drain?-287.jpg   Why does my LG G2 have rapid battery drain?-289.jpg
    08-29-2015 07:42 AM
  4. B. Diddy's Avatar
    Is there a menu that shows how your mobile signal has been? It's usually part of the graph--can you tap the graph and make it fullscreen? Poor mobile signal can eat up battery.
    08-29-2015 06:32 PM
  1. Battery apps
    By djdonnyk in forum Samsung Galaxy S6
    Last Post: 09-03-2015, 11:21 PM
  2. Replies: 2
    Last Post: 08-23-2015, 05:46 PM
  3. Replies: 1
    Last Post: 08-22-2015, 08:29 AM
  4. Replies: 1
    Last Post: 08-22-2015, 07:53 AM
  5. My LG G3 is not notifying me when receiving text messages
    Last Post: 08-22-2015, 05:48 AM
