1. Denise Trinkle's Avatar
    I like to get some help, on fixing my phone. Ever since I put my work email on my phone, I have to use pin numbers to get into my phone. I hate it. Everything is blocked out on lock screen settings outside of password for high security. Even in my security settings in general settings Clear credentials is blocked out.. I have took off my work email off but did not fix the problem. Any Suggestions??? I have been working on this for sometime. Still not getting it fixed. I really do not want to Backup and reset!
    09-14-2015 11:22 PM
  2. nahoku's Avatar
    Perhaps installing your company's email has somehow set your company as a phone administrator. I don't know how installing email would mess with your lock screen. I'm retired though, so not sure what they do nowadays.
    09-15-2015 12:13 AM
  3. MischiefsMommy's Avatar
    Do you know the password to get in?
    Sent from my SM-N900P using Tapatalk
    09-15-2015 02:26 AM
  4. MischiefsMommy's Avatar
    If you know the password unlock the screen. Then go to I believe its under device and turn off the lock screen. Then restart your phone. This should fix the problem. If it doesn't I'm sorry I do not know.
    09-15-2015 02:37 AM
  1. How can I get my LG G3 camera working?
    By Skanlez2 in forum LG G3
    Last Post: 09-19-2015, 01:38 AM
  2. HTC one m8 big priblem plzz help
    By Alonzo_sy in forum HTC One M8
    Last Post: 09-16-2015, 10:53 AM
  3. Persistent Loss Of WiFi...quick help needed, please.
    By mcoomer in forum Samsung Galaxy Note 5
    Last Post: 09-15-2015, 06:01 PM
  4. How do I uninstall cm security?
    Last Post: 09-14-2015, 11:53 PM
  5. My photos delete button is nonexistent, how can I get it?
