1. Neshiyo Tassa's Avatar
    I am using Gigabyte GSmart Classic Dual Sim with 5.1 Lollipop.
    What happened is that today I tried to expand Wireless&Networks settings sub menu, and after clicking 'More' process crashed. I tried to clear app data, but it also makes the app to crash. All other options from that menu (Wi-Fi, Bluetooth, SIM cards and Data usage) work fine, but clicking 'more' to expand the menu makes the process crash. Attempting to open VPN menu from Search also makes process crash. There are 4 Setting options (VPN being one of them) that I cannot access because process crashes every time.
    Edit: it is More option and everything under it that is bugged.
    11-21-2015 06:52 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this persist after a reboot? How about Safe Mode? On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    11-21-2015 02:51 PM
  3. Vladan_Zlatic's Avatar
    Hi guys, I have the same problem as Neshiyo Tassa same to the letter. And my friend has this kind of the problem but on Audio Profiles button, so now it can't make the changes for the ringing tone etc, it always crashes?
    Can you please advice me on this, how to fix?
    12-31-2015 11:02 AM
  4. Antal Uszkay's Avatar
    Hi Guys, recently i ran into exactly same issue on same phone. I think i found the reason and a solution. After 5 -6 factory restore i realized that updated PlayStore service ruin the stable run. My suggestions to do:
    - go to Settings ->Safety backup and restore , do the factory restore. This will install the original components of Android that worked well.
    - during the setup do not connect to your Google account, add it later (this prevents you from restoring bad app settings automatically)
    - when all finished open the Play Store -> My applications ->Setting. (This will ask your google account/password of course)
    Disable the automatic update of applications. Close Play Store or add any other app you still need.
    - check under Settings -> Accounts if "Google" is added. (now you connected your account to phone as should be)
    - now you can check under "Safety Backup and Restore" if backup/ options are activated by your preference
    (if you had Connections saved to phone before, then it will be sync back to phone again )
    one notice: i removed the scrap Battery doctor right after the factory restore, saves memory
    one more notice: do not ever remove Clean Master, then you can start from right the beginning. Somehow it is needed for Android, if it was removed then the "com.android.settings has stopped" immediately returned. Now i'm going happy beside 370Mb free RAM.
    Good luck
    antivirtel likes this.
    02-02-2016 05:09 PM
  1. 201.34 MB junks found! Recommend to clean
    By N4Newbie in forum Android 6.0 Marshmallow
    Last Post: 03-28-2016, 02:29 PM
  2. Do I need to buy fast charger for Samsung s6 edge
    By George Huxham in forum Ask a Question
    Last Post: 03-25-2016, 05:17 AM
  3. Replies: 2
    Last Post: 12-11-2015, 02:01 AM
  4. Email downloading - how to prevent battery drain
    By olmir in forum ASUS ZenFone 2
    Last Post: 11-24-2015, 12:39 PM
  5. If I delete my Gmail account will I be able to create another one?
    Last Post: 11-21-2015, 07:08 AM
