1. Emanuel2558's Avatar
    Hey I need some help developing an application that can make a hotspot and in the same time to don't make any routing via data connection ( Access point ). The first part I made it (part with hotspot ) but the second part I can't figure it out ( no routing ), on an Android last version of OS. So please if you can help me to stop redirecting packages from the client via hotspot to data connection, I would be thankful
    01-12-2016 09:37 AM
  2. Almeuit's Avatar
    Could you clarify more? You are trying to have the hotspot work but not use the data connection? Are you just trying to have the hotspot be used as a LAN router?
    01-12-2016 09:40 AM
  1. My battery is slow charging, how can I fix this?
    By AC Question in forum Batteries
    Last Post: 01-13-2016, 10:47 AM
  2. i want to root lenovo P70a lollipop version
    Last Post: 01-12-2016, 12:09 PM
  3. Replies: 1
    Last Post: 01-12-2016, 09:51 AM
  4. Remember WiFi, but use a manual connect.....
    By telrod11 in forum General Help and How To
    Last Post: 01-12-2016, 09:36 AM
  5. Dockable speaker for Android
    By blackhawksfan75 in forum Ask a Question
    Last Post: 01-12-2016, 09:33 AM
