1. AC Question's Avatar
    3 Chinese phones I have tried do NOT automatically re-connect to Saved WiFi Networks if the screen is locked, (not off - just screen locked and black).
    Example: come home from work with phone in pocket ( phone is on with screen locked), the phone should automatically connect to your home WiFi without you touching it or unlocking the screen -yes ? My old Samsung Galaxy Mini, and Moto G does.
    These 3 phones don't - (Cubot H1, Leagoo Elite 5, Bluboo X550 ), I have been though all the seetings, and researched this till I am blue in the face, but no joy.
    I had a sellers on Amazon test this senario on a Chinese phone before I ordered it, he confirmed it, so didn't order it.
    So is this a bug in the Chinese version of Android, or is it a feature to make sure you using up your data allowance and hence spending money you wouldn.y otherwise have done.
    Happy days :-)
    01-23-2016 06:17 AM
  2. dpham00's Avatar
    Probably just a problem with your specific devices /manufacturers. I have phones from other Chinese companies like zte and Huawei and no problems.
    01-23-2016 07:45 AM
  3. Rukbat's Avatar
    Many cheap Chinese phones have little "imperfections" like that. Smart WiFi Toggler usually solves that particular problem. Or using Tasker and geofencing your house to turn the screen back on would also do it.
    01-24-2016 12:24 PM
  1. Replies: 2
    Last Post: 04-25-2016, 04:49 PM
  2. How does Marshmallow perform with only 1GB RAM ?
    By David Alfredo in forum Android 6.0 Marshmallow
    Last Post: 01-29-2016, 06:35 AM
  3. My Infinix Hot 2 phone has been updating for over 2 hours, is this normal?
    Last Post: 01-27-2016, 08:24 AM
  4. Replies: 2
    Last Post: 01-24-2016, 12:11 PM
  5. Is there any way to download photos from your Samsung phone remotely?
    By tanniharpz in forum General Help and How To
    Last Post: 01-23-2016, 06:26 AM
