1. AC Question's Avatar
    I have a Samsung Galaxy S5 (SM-G900F) with Android 5 and when i change from network to an other network internet wil mostly first apply when i restart the phone.
    I heard that this problem happens by Android 5 and not by Android 5.1.
    Is that possible?
    Thanks in advance.
    01-29-2016 02:04 PM
  2. Wim Snel's Avatar
    Is dit zo'n gekke vraag dat ik geen antwoord kan krijgen?
    Om te kunnen reply-en heb ik me geregistreerd.
    01-31-2016 02:51 AM
  3. itguyjax8430's Avatar
    Is that possible?
    Thanks in advance.
    Welcome to Android Central!
    There were probably quite a few changes made when they updated from 5.0.1 to 5.1. It was probably bug fixes and some enhancements.
    02-04-2016 07:36 AM
  4. belodion's Avatar
    I'm not sure what that means, but the 5min answer cannot be guaranteed, either for a registered member or a guest poster.
    02-05-2016 05:26 PM
  5. eviltony's Avatar
    Android 5 is a buggy version which caused my phone lagged so much, I upgraded my phone to 5.1.1 and it runs smoothly since. Recommend you to upgrade to 5.1.1
    02-10-2016 05:34 AM
  1. Powerbank that can continuously power an Android smartphone
    Last Post: 05-08-2016, 09:44 AM
  2. Replies: 3
    Last Post: 02-24-2016, 12:42 PM
  3. Replies: 2
    Last Post: 02-04-2016, 07:24 AM
  4. Replies: 2
    Last Post: 02-04-2016, 07:22 AM
  5. Replies: 1
    Last Post: 01-29-2016, 02:23 PM
