1. AC Question's Avatar
    Hi - I recently purchased a Chinese smartphone while in China and I would like to install a "Western" version of the Android OS. I tried installing the Google Play Store by downloading the apk but it would not run properly, hence the desire to reinstall.
    Its current stats are:
    Model: TCL_P620M
    Hardware version: S01
    Android Version: 5.0
    Build Number: TCL_P620M_V2.7
    There are also some other info like "baseband version" and "kernel version." If that information is also needed, please let me know and I can post them as well. Can someone please help? I know next to nothing about smartphones....
    Thank you!
    02-03-2016 01:29 PM
  2. anon(632115)'s Avatar
    The problem you will find is that there is little or no support for such devices. All I could find was stuff in Chinese. You certainly won't find custom roms. Bottom line is there's not a lot you are going to be able to do with it. There is a Chinese devices Web site which you may wish to check out
    02-03-2016 01:35 PM
  3. Rukbat's Avatar
    You need to download the manufacturer's flashing tool and a stock ROM file. If you can't read Chinese, or know someone who can, your chances are fat, slim and none.
    02-03-2016 05:38 PM
  1. Replies: 5
    Last Post: 02-11-2016, 12:58 PM
  2. Replies: 8
    Last Post: 02-04-2016, 07:50 AM
  3. My Samsung Galaxy S Mini 3 keypad has stop, what do I do?
    By AC Question in forum Samsung Galaxy S3 Mini
    Last Post: 02-03-2016, 02:10 PM
  4. Launcher has stopped/com.android.systemui has stopped, what do I do?
    Last Post: 02-03-2016, 02:04 PM
  5. how well has your z2 aged?
    By Carlos Thwaites in forum Sony Xperia Z2
    Last Post: 02-03-2016, 12:47 PM
