I just pulled my tablet off the charger bout an hour ago and !y tablet is already at 46% I make sure my screen brightness is down and my apps are closed out. I just bought it about a month ago.
Your battery is draining slow or fast? Make sure you charge from 0% to 100% at the first time you turn the tablet on or you will damage the battery. Try to uninstall apps that consume a lot of energy or disable the ones you don't use.
