1. mellisarae's Avatar
    I just pulled my tablet off the charger bout an hour ago and !y tablet is already at 46% I make sure my screen brightness is down and my apps are closed out. I just bought it about a month ago.
    03-10-2016 08:57 PM
  2. zoedimax725's Avatar
    check if you have unnecessary radios on. Turn off wifi, bluetooth, mobile data and especially GPS if you are not using it
    03-16-2016 07:03 PM
  3. Wolfie ProHD's Avatar
    Your battery is draining slow or fast? Make sure you charge from 0% to 100% at the first time you turn the tablet on or you will damage the battery. Try to uninstall apps that consume a lot of energy or disable the ones you don't use.
    03-19-2016 08:27 AM
  1. Why are my texts bubbles different colors?
    Last Post: 03-14-2016, 07:24 PM
  2. My phone is totally out of function
    Last Post: 03-10-2016, 10:03 PM
  3. Replies: 1
    Last Post: 03-10-2016, 09:32 PM
  4. Replies: 0
    Last Post: 03-10-2016, 08:55 PM
  5. Replies: 0
    Last Post: 03-10-2016, 08:45 PM
