1. nababy12's Avatar
    when ever i connect my device to the computer using adb shell it tells me ( device not found).
    pls can anybody help me out.
    03-15-2016 09:58 AM
  2. itguyjax8430's Avatar
    Welcome to Android Central!
    Do you have USB debugging on? If you do not you need to turn it on.
    Go to settings, about device, go to build number, tap it 5 times or until it says Developer Options enabled. Go back out to settings, you should see Developer Options. Go in there scroll down to USB Debugging that should fix you up.
    03-15-2016 10:03 AM
  1. Mobile data not working
    By andonakis in forum Nexus 6P
    Last Post: 01-09-2017, 10:31 PM
  2. gear help
    By welshmikie in forum VR Headsets
    Last Post: 03-15-2016, 04:54 PM
  3. Can you get a Music player widget on the lock screen S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-15-2016, 04:21 PM
  4. Replies: 3
    Last Post: 03-15-2016, 02:22 PM
  5. Replies: 1
    Last Post: 03-15-2016, 09:35 AM
