1. AC Question's Avatar
    Hi, I can't believe this is really happening right now. With the new android 5.1.1, I cannot make it silent. A coworker and I fiddled and there is no info online. It demands vibrate or noise, this is absolutely absurd...before I got a new replacement phone, the old android worked! You could go completely silent with no vibrate. I have to turn my phone completely off at work and shouldn't have to. Why is this and is there some special way to turn the vibrate off?
    03-15-2016 11:04 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? You might need a 3rd party app, like Volume Ace.
    03-15-2016 11:34 AM
  3. SnowyRa1n's Avatar
    That's unusual, usually when you put it in Mute in silences everything. Have you tried Do Not Disturb mode?
    03-15-2016 01:38 PM
  4. codyc4321's Avatar
    no, I don't know how. I'll google it. I tried everything
    03-15-2016 03:28 PM
  5. B. Diddy's Avatar
    Which phone do you have?
    03-16-2016 11:40 AM
  6. SnowyRa1n's Avatar
    Settings > Sound and Notification > Scroll to "Notification" at the bottom and click Do Not Disturb
    03-16-2016 09:04 PM
  1. I hate Android's "simpler" volume controls
    By Dom12 in forum Android 6.0 Marshmallow
    Last Post: 06-28-2016, 01:05 PM
  2. Best Android Wear Option?
    By hjmjr in forum Android Wear / Wear OS
    Last Post: 03-22-2016, 09:33 PM
  3. Replies: 2
    Last Post: 03-16-2016, 04:17 PM
  4. Beta Android 6.0.1
    By Paulo de Oliveira Neto in forum Sony Xperia Z3
    Last Post: 03-16-2016, 10:12 AM
  5. Bush Spira C1 5"Smartphone won't write media to "SD Card" by default
    By Simon Belfield 1965 in forum Ask a Question
    Last Post: 03-15-2016, 10:59 AM
