1. klear6's Avatar
    I am using an unrooted Samsung Galaxy Tab S2 running Lollipop and my widgets keep disappearing from:
    My homescreen (Lightning Launcher)
    My sidebar (Glovebox)
    My lockscreen (Lockr)
    This is getting extremely frustrating because I have already tried a factory reset and as soon as I get most things set back up my widgets start disappearing again! I have done research online and I haven't come up with anything that helps.
    It seems to happen MOSTLY when I power off my device and turn it back on.
    What is happening here and how do I fix it? I will be happy to go into as much detail as I can about everything I have installed, all of my settings, and whatever else if someone will please help me. Arg! Also, if someone does figure this out can they give me the reasoning behind the solution?
    PS: I have almost the same setup on my HTC One m9 and this is not happening to that device. I do not have Lockr on it but that is really the only major difference.
    07-04-2016 07:34 PM
  2. Javier P's Avatar
    Are you using an SD card in your Tab to save apps or widgets?
    07-04-2016 07:50 PM
  3. klear6's Avatar
    No. All my apps with widgets are on the device.
    07-12-2016 09:28 PM
  1. Thinking of swapping my Nexus 5X for the S7.
    By ianhanson85 in forum Samsung Galaxy S7
    Last Post: 07-06-2016, 10:14 AM
  2. How do i remove sd card from zte compel
    Last Post: 07-04-2016, 09:32 PM
  3. Why do I get a Phantom notification at 8pm every day?
    Last Post: 07-04-2016, 07:21 PM
  4. Replies: 0
    Last Post: 07-04-2016, 06:42 PM
  5. Replies: 1
    Last Post: 07-04-2016, 06:06 PM
