1. AC Question's Avatar
    phone running 5.0.2
    When listening to music even the lowest volume setting using the side button is too loud over headphones. Is there a way to adjust volume lower?
    07-12-2016 10:45 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which phone? Does this happen on all headphones? How loud or soft is it through the main speaker at the lowest volume setting?
    07-13-2016 01:53 AM
  3. wayne_xxxx's Avatar
    Which phone? BLU studio 6
    Does this happen on all headphones? yes
    How loud or soft is it through the main speaker at the lowest volume setting? too loud
    since posting this I see other people have this problem and there is even an app to provide finer volume control
    B. Diddy likes this.
    07-14-2016 05:00 PM
  4. B. Diddy's Avatar
    Can you show us the link for that app?
    I've noticed that the lowest volume setting on the Honor 5X is also note quite that low. It's presumably dependent on the firmware.
    07-14-2016 08:13 PM
  5. wayne_xxxx's Avatar
    search the play store for "fine volume control", you will see a couple of apps
    07-15-2016 09:49 AM
  6. Ida Ma's Avatar
    Hi, I have the same problem. I'm not using headphones, but playing little games using just the phone speaker. The lowest volume setting is too loud when I don't want to disturb other people.
    My phone is Sony Xperia XA, bought it just this week. The Fine Volume Control app from Play Store doesn't work with the physical volume buttons on the phone.
    07-15-2016 01:08 PM
  7. wayne_xxxx's Avatar
    I should add that I havent tried those volume apps
    07-15-2016 02:01 PM
  1. All the pokemon I see are running
    By mstrblueskys in forum Pokemon Go
    Last Post: 07-12-2016, 03:11 PM
  2. Optimal Phones/Cases for AR Games
    By darknyght00 in forum Pokemon Go
    Last Post: 07-12-2016, 11:10 AM
  3. Replies: 0
    Last Post: 07-12-2016, 10:32 AM
  4. How do I get started on the Samsung music app?
    By AC Question in forum Android Apps
    Last Post: 07-12-2016, 10:25 AM
  5. Can I use an external mic with the Galaxy S7 to capture a video?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-12-2016, 10:19 AM
