1. QwavesX's Avatar
    I was trying to play hacked Pokemon Go via my Verizon Samsung Galaxy S4 (SCH-1545) and i watched a video trying to get it working. i downloaded xposed installer, framework, and twrp. i went through this walk through process rebooted it and now it reads "start up failed Your device didn't start up successfully. Use the Verizon Software Repair Assistant on a computer to repair your device." and in the top left corner in red it says " Secure Fail: Kernel" Im not very tech savvy and just wanted to try it. If you can help thanks in advance!
    07-27-2016 07:38 PM
  2. mjl574's Avatar
    If that doesn't fix the issue, you'll need to do a factory reset.
    07-28-2016 09:37 AM
  3. anon(632115)'s Avatar
    A factory reset won't fix that problem. Some reading for the OP [GUIDE] No-Wipe Factory Images (Restore from… | Verizon Samsung Galaxy S 4
    07-28-2016 09:45 AM
  1. Send Calls to Voice Mail?
    By zhris in forum Samsung Galaxy Note 4
    Last Post: 07-28-2016, 04:17 PM
  2. Why Do I have Duplicate photos in 2 locations on phone
    By 25544 Norad in forum Samsung Galaxy Core Prime
    Last Post: 07-28-2016, 03:27 PM
  3. "Storm Alert" KTS scale from 100 to -100 : I don't understand
    Last Post: 07-27-2016, 08:19 PM
  4. Replies: 1
    Last Post: 07-27-2016, 07:34 PM
  5. Why is the hashtag missing on my Samsung Galaxy S6
    Last Post: 07-27-2016, 07:09 PM
