1. pratyaksh tyagi's Avatar
    i have a lyf flame phone it was working fine but after intalling xposedv72sdk22.zip it got into booloop(struck on bootlogo)
    i have tried:
    1. wipe data/factory reset
    2. wipe cache partion
    it is on stock recovery and rooted.tried installing zips but signature verification error.
    there is no stock rom available on the net for this phone.
    help me to repair it as i want to enjoy 4g sim
    09-01-2016 07:50 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You will probably have to reflash the stock ROM. I found this: Lyf Archives - Stock Firmware
    I am not sure which file to use, as there are 2 different Flame phones.
    09-01-2016 08:40 AM
  3. pratyaksh tyagi's Avatar
    sir there is no stock rom for my device(ls-4001) on the link.
    can i flash one of them? will it brick my device??
    please tell me another method to save my device help please
    09-01-2016 10:09 AM
  4. Golfdriver97's Avatar
    I follow the rule of thumb that it will. Only flash ROMs for the exact same model.
    09-01-2016 01:03 PM
  5. pratyaksh tyagi's Avatar
    ok but now tell me what to do so that i can bring life back to my phone.
    dont tell the warrnty solution
    help
    09-02-2016 10:23 AM
  6. Golfdriver97's Avatar
    I can't find anything for a 4001. I keep getting other model numbers. Have you contacted the company to see if they can send you the stock files?
    09-02-2016 11:50 PM
  7. pratyaksh tyagi's Avatar
    not yet
    09-03-2016 10:17 AM
  8. pratyaksh tyagi's Avatar
    i am trying to disable xposed through adb but error:closed comes whenever i try to access adb shell
    help
    09-03-2016 10:49 AM
  9. Golfdriver97's Avatar
    With something like this, as far as I know you need to flash a stock ROM. I've been looking around a little, but still can't find anything for your model.
    09-03-2016 04:54 PM
  10. pratyaksh tyagi's Avatar
    i wished i had a custom recovery
    09-04-2016 03:17 AM
  11. pratyaksh tyagi's Avatar
    i have contacted the company for stock file waiting for response...
    09-04-2016 03:18 AM
  12. pratyaksh tyagi's Avatar
    cheers!! i managed to get the stock file from an agent for free!!
    09-06-2016 03:55 AM
  13. Golfdriver97's Avatar
    Sorry for the delay. Glad you got the stock file. Did everything go OK?
    09-07-2016 07:46 PM
  14. ssebax's Avatar
    i have tried:
    www. celularsoftware. com. ve /2016/06/rom-stock-3nstar-lyra-sp-4001.html?m=1
    Please not mod this post.
    I found this stock rom, use Google translate. x3
    09-08-2016 06:10 AM
  15. chandraprakash khatri's Avatar
    Provide if you can
    09-09-2016 02:30 AM
  16. chadder43's Avatar
    Another thing to check is carrier based model numbers, for example the US cellular galaxy s6 has a different model number then the sprint or Verizon ones, but the phones are the same and the stock rooms will work on them, actually to root the US cellular version I used Verizon s6 method.
    If your phone has a carriers name on the device somewhere that would be the first thing I would check into. When your phone booted up before did a carriers name show up in one of the boot screens?
    Also found this with a quick search
    http://sineshgsm.com/lyf-official-stock-rom-tool-download
    the model is listed there I would give it a shot
    09-10-2016 08:12 AM
  17. pratyaksh tyagi's Avatar
    09-10-2016 10:08 AM
  1. Replies: 2
    Last Post: 09-17-2016, 07:03 PM
  2. Mophie Moto Mod in the works?
    By sangs in forum Moto Z Force
    Last Post: 09-03-2016, 11:12 AM
  3. "Android is upgrading" everytime when the phone is turning on
    By dalbich in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 09-03-2016, 02:20 AM
  4. [HELP] Why isn't my OTG showing up?!
    Last Post: 09-01-2016, 02:54 PM
  5. !! HELP !! phone stuck in bootloop
    Last Post: 09-01-2016, 07:42 AM
